I've set up an audio list within a production and have added 5 songs to an input list. When adding a new song, I click on add, then browse to my PC and choose an mp3 file. It then gets added to the list.
The problem is when I access the production on another PC. Everything else transfers across, as the the input videos etc are on Onedrive so it works. However the list entries are empty. I can't see where those files are stored (they are nowhere to be found). Anyone know how lists work and where Vmix stores the files? Thanks
Joined: 5/15/2022(UTC) Views messages in topic : 19  Location: Ohio Was thanked: 2 time(s) in 2 post(s)
The files are located at the origional location. vMix lists just link to the file location. So if the origional files is located on the C drive in a folder, that's where the file is located. When you select a file from a list, vMix just folows the chain to that loacation. That's why if you move the file, vMix cannot find it when selecting it from the list.
