clincoln777
#1 Posted : Thursday, September 18, 2014 8:23:16 PM(UTC)
clincoln777
I am evaluating vMix and need to find out if it is capable is streaming 3 simultaneous RTMP feeds. We do three feeds to support HD, SD, and mobile. Does anyone know if that an be done via the vMix software?
ask
#2 Posted : Thursday, September 18, 2014 9:04:58 PM(UTC)
ask
This is done via the encoding software that vMix connects to. i.e FMLE. You setup multiple streams in that tool. Alternatively you can use a CDN that takes a single stream and breaks it into multiple streams. YT live is an example of this.
sinc747
#3 Posted : Thursday, September 18, 2014 9:51:02 PM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
If you want to do all this from within vMix...
In vMix 13 you have the option to set up 1, 2, or 3 separate bit rates all to the same CDN assuming the CDN can accept multiple streams. This is done through Streaming Settings (click the gear cog next to Stream at bottom of the vMix window). Then click the gear cog opposite the Quality box (at bottom of window). That opens the Streaming Quality window where you can set up to 3 different bit rates and resolutions.
Basically it just uses FMLE in command line format and fills in the three blanks in FMLE for Video Encoding.
Check with your CDN to see if they can handle three streams from FMLE as your encoder.
clincoln777
#4 Posted : Thursday, May 9, 2024 1:47:40 AM(UTC)
clincoln777
Thank you
#5 Posted : Thursday, May 9, 2024 4:57:24 AM(UTC)
Originally Posted by: clincoln777 Go to Quoted Post
Thank you
Lol only took you 10 years
