bogdan
#1 Posted : Sunday, April 28, 2024 9:35:57 AM(UTC)
bogdan
I've searched far and wide and couldn't find much. I was looking if anyone knows of a MIDI device or any other device where it can be used as an external device for the T bar fader. I am looking for for something that I can change with the tempo of our worship songs that could be programmed through VMIX. I currently use the StreamDeck XL for shortcuts but was looking for another device that can help with this.
Thanks in advanced.
sinc747
#2 Posted : Sunday, April 28, 2024 11:16:41 AM(UTC)
sinc747
X-keys have several controllers that have T-bars and are already set up to be used in vMix.
X-keys T-bar controllers
- Tom
bogdan on 5/1/2024(UTC)
bogdan
#3 Posted : Wednesday, May 1, 2024 7:49:35 AM(UTC)
bogdan
- Tom
Thank you. Prices are a bit steep but I guess that's the name of the game.
Roy Sinclair
#4 Posted : Thursday, May 2, 2024 7:38:07 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
- Tom
Pricey but worth it. You can use the buttons to trigger all manner of actions in vMix. I've got a 64 key (no t-bar) one and only 6 keys are not in use (yet).
sinc747
#5 Posted : Friday, May 3, 2024 12:50:24 PM(UTC)
sinc747
You might also look at the $99 Behringer X-Touch Mini. It's a MIDI device that should work with vMix.
- Tom
bogdan on 5/5/2024(UTC)
mavik
#6 Posted : Friday, May 24, 2024 4:39:09 AM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
I use a https://monogramcc.com/ fader as a T-Bar. Works like a charm.
