Joined: 2/27/2024(UTC) Posts: 8  Location: Missouri Thanks: 2 times
Hello, I am making a Churh Logo on Canva. When I use the Logo on a Tile it isn't big enough to see on the Screen. What size should I use?
Joined: 11/23/2020(UTC) Posts: 252  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: Michael7687  Hello, I am making a Churh Logo on Canva. When I use the Logo on a Tile it isn't big enough to see on the Screen. What size should I use? What is your screen resolution (that you broadcast)? Make the image to fit that for full screen use, also think of half screen and quarter screen. If you plan to broadcast larger formats later make those as well. Also consider a very small version with a transparent background you can use as a miniature logo for the bottom of the screen that you can use like TV channels do to periodically brand your stream, it can also be used as a logo in many of the GT Titles.
