Feature Requests
Replay Export - Select Audio
Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
When exporting a replay event it would be helpful to be able to select the audio source in the export dialog.
For played out replay's I use 'Follow' as the audio source to get just that inputs audio. When exporting events I sometimes what that audio but, more frequently, want the audio source selected as 'Master'. I'm exporting events to quickly post to social media so want commentary audio on those.
I can go into the replay settings, change the playback source, export the replay and change the playback source back but, as I add more automation, there is a chance of a replay being triggered to air while I have the audio configured for export.
Allowing selection of the audio source in the export dialog would make this process more efficient.
The function ReplaySetAudioSouce would help but, while there is ReplayExportLastEvent, the is no ReplayEportSelectedEvent. Adding that would also but be a good solution to me. The flexibility of having both would be ideal.
Feature Requests
