Pepsi(~)
#1 Posted : Friday, April 19, 2024 1:01:11 AM(UTC)
Pepsi(~)
Netherlands
I got a request from a client. for a lower third.
that has a transition in that I can not get to work.
most are horizontal or vertical transitions in.
this one is a rotation in when the centerpiont is in the bottem right corner.
and needs to rotate in for 10 or 15 degrees.
not even sure I can do this.
so I need advice. is this possible?
or do I need to do with an ImageSquence ? never used it. and I could not find much about it.
below an mokeup
TransitionIn 10 degree angle.png (1,622kb) downloaded 6 time(s).
#2 Posted : Friday, April 19, 2024 3:06:07 AM(UTC)
below an mokeup
Image sequence. vMix has a tutorial video on their channel.
Pepsi(~)
#3 Posted : Monday, April 22, 2024 12:03:17 AM(UTC)
Pepsi(~)
Netherlands
Thanks Doggy,
It worked. I was a bit struggling to build it.
I first try to use just powerpoint and to create a mask video (Black white and grey), but I was struggeling to get it as a export with an alpha channel.
So I used 2 tools to build the animation.
1. Powerpoint. Some tricks to use the rotate option (spin) because it will us the center of the Triangle and not the corner. If needed I will do a step by step explenation
2. Apple Keynote. I have loaded the Powerpoint in keynote. Because with keynote you can remove the background. And with the custom export to video (prores3333) it will make an alpha channel.
Keynote has created a mov file that Vmix video converter converts to images. That I can reuse in the GT title designer.
The result is perfect.
Again thank you doggy to help me with the next steps in the challange
