Feature Requests
Stream Deck + Feature Request
Joined: 7/24/2023(UTC) Posts: 1  Location: UK Thanks: 2 times
As a vMix user I have just migrated from my Loupedeck Live to a Stream Deck +. One of the functions of the Loupedeck vMix template was the ability to scroll through the inputs (back and forth) using a rotary control which you then pressed to take the chosen input to preview. Is this possible to recreate for the Stream Deck + ?
To my knowledge it isn't possible natively. You would need script or something. I struggle with the rotary knob implementation as often things don't just work as you would expect them to.
I tried to PAN a PTZ with one knob. I couldn't get it done properly at all.
 1 user thanked mavik for this useful post.
Joined: 2/7/2024(UTC) Posts: 197  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
Should be able to do this if you use Bitfocus Companion to control your Stream Deck
 1 user thanked knbPixels for this useful post.
Feature Requests
