obau
#1 Posted : Sunday, April 7, 2024 10:20:15 AM(UTC)
obau
Could you please add support for additional fullscreen outputs? At the moment there is only support for two fullscreen outputs which is not sufficient for most modern systems/setups.
Thank you.
mm.se
#2 Posted : Tuesday, April 23, 2024 5:19:09 PM(UTC)
mm.se
A third Fullscreen Output would be great and should be pretty easy with current hardware.
Maybe put on restrictions against older grafic cards and only allow newer version to use it.
