mnmilos
#1 Posted : Monday, April 1, 2024 10:23:19 PM(UTC)
mnmilos
Serbia
Hello.
I have one feature request about t-bar function in vMix Replay section.
EVS and Ross system can play video if you move t-bar. To many operators suggest this to us so now we are sending this info to you.
If you can add option to Enbale/Disable play video replay from T-bar.
You can see how it is done on Ross Replay:
https://help.rossvideo.c.../Replay/Panel-T-BAR.html
sinc747
#2 Posted : Wednesday, April 3, 2024 12:17:47 PM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
If you are using a separate device with a T-bar, then you can change the vMix Shortcuts that executed by the T-bar to anything you want. No change in vMix required.
- Tom
