maxdaniel98
#1 Posted : Thursday, August 20, 2020 5:14:12 AM(UTC)
maxdaniel98
Netherlands
We are using vMix al lot for it's vCall function.
To integrate this more with the production workflow, I would like to be able to get more info from vMix inputs which are vMix calls.
I would like to be able to:
- Get the status of a vCall input (connecting/connected/disconnected)
- Get the status of a microphone or webcam (enabled/disabled on the user's side)
- Get the password or vCall URL for an vCall input
- Reset the password for a vCall input
This way I could integrate or create a platform for the producers to prepare vCalls and monitor them.
Also, I can't seem to add a VideoCall with the AddInput shortcut.
I would love to hear wether this is possible!
Kind regards,
Max van den Bosch
United
birgerh
#2 Posted : Monday, March 18, 2024 8:33:22 PM(UTC)
birgerh
Norway
+1 for making it possible to add videocall (vMix call) with AddInput.
mavik
#3 Posted : Thursday, March 28, 2024 11:07:50 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
+1 adding
- set a default image in case the input is down or new
- select not only outputs but also inputs as the video source
- remote control of cam/mic
spinfold
#4 Posted : Saturday, March 30, 2024 1:43:19 AM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
+1 for having video/mic status in the master XML.
mnmilos
#5 Posted : Monday, April 1, 2024 11:19:45 PM(UTC)
mnmilos
Serbia
