NDI
NDI output on OBS Studio
I have a problem with receiving NDI signals from Vmix to OBS, OBS recognizes the sources but does not display the video to me (black screen), using the router tool I can "see" the video but I cannot display it in the "monitor" tool , how can I solve it?
Joined: 12/27/2023(UTC) Posts: 12  Location: Texas Thanks: 2 times
Sorry for the delay, but what you are describing sounds like a network latency problem. Keep in mind that NDI doesn’t work on WiFi, so both systems need to be wired. If you have an absolutely perfect WiFi signal running at 5ghz, with no other traffic, then it should work, but I have been burned by NDI over WiFi inconsistencies too many times to trust it. I would only ever run NDI HX over WiFi.
NDI
