berryv97
#1 Posted : Tuesday, March 5, 2024 3:48:48 AM(UTC)
berryv97
I've been working on a web service to control vMix remotely for a few weeks. I'm sharing the GitHub link in hopes that it will be useful to others.
https://github.com/vincentberry/vMix-remote
Luis70
#2 Posted : Tuesday, March 5, 2024 9:14:55 PM(UTC)
Luis70
Grenada
Was thanked: 11 time(s) in 11 post(s)
I downloaded the app and am trying to get it to work, but I do not understand how to open, load ar apply the app....How do I launch it
berryv97
#3 Posted : Wednesday, March 6, 2024 12:10:27 AM(UTC)
berryv97
This app runs on Docker, you need to download and install Docker, then pull the image.
https://www.docker.com/products/docker-desktop/
https://hub.docker.com/r/vincentberry/vmix-remote
Luis70
#4 Posted : Thursday, March 21, 2024 11:57:24 PM(UTC)
Luis70
Grenada
This is the most complicated app I have ever tested...I launched the app, and tried to pull your remote your program....spent a long time trying to pull it in, cannot locate it, so I gave up....can't afford to waste time on such.....was hoping to test it to give you some feedback so you can do more development, but it seems to be a time waster for me....just can not find it to test...I thought that adding it in the Docker search bar it would be easy to find, but no, searched through over 1000 listed apps, and can not find it so that is a no-go for me.....
berryv97
#5 Posted : Sunday, March 24, 2024 11:01:55 PM(UTC)
berryv97
I'm sorry that you're having trouble. Indeed, if you've never used Docker before, it can be a bit more complicated. However, if you want to search in the Docker search bar, the easiest way is to type: "vincentberry/vmix-remote". Meanwhile, a demo version is now available at vmixremotedemo.servehttp.com.
