storage disc disconnects unexpectedly during using Vmix
configuration: Intel Core i7-7700, the GTX 1050 and two m2 disc: 1 – disc C) system and 2- disc D) storage, 3 cameras instant replays
During streaming on youtube, I use instant replays storages on disc D. Some times (2 – 3 per hour) storage disc disconnects unexpectedly and I vmix hangs. This never happens with other application or ‘normal’ using computer. So, can there be a problem with vimx. I'm wondering – it may cousing by big using storage storage disc (it got hot to much or it hasn't enought power)? I use win 10.
Have you got experience with it?
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
Sounds like an issue with the SSD, like its resetting when put under heavy load (instant replay causes continuous use for extended periods of time). Make sure you're using a quality name brand SSD.
Both disc seems to be good. Storage disc: 970 EVO Plus Samsung NVMe M.2 (1 TB)
with heat sink plate.
Maybe the cooling (heat sink plate.) is insufficient?
