Kietlin
#1 Posted : Friday, March 22, 2024 7:26:07 AM(UTC)
Kietlin
Poland
I would like to add points to two scoreboards using one button in Web Controller. I know that its easy while using pc keyboard because i can trigger few shortcuts with one key, but it will make also few buttons in web controler. Is there any way to add points to two scoreboards using only one button in Web Controller?
dmwkr
#2 Posted : Saturday, March 23, 2024 2:51:16 AM(UTC)
dmwkr
Yes, if your vMix version allows scripting. Just put the two commands into a script and set a shortcut to start the script.
Kietlin
#3 Posted : Saturday, March 23, 2024 7:59:37 AM(UTC)
Kietlin
Poland
Thanks, it is what i was looking for. In the meantime I found that you can change Data Source row using shortcut. I used it to change points in scoreboards.
