4 channel audio on SDI ext output
Joined: 3/13/2024(UTC) Posts: 4  Location: Ulaanbaaar
Hello there?
I need to send 2 separate audio channels over SDI. When i send them over SRT it is good and i can separate those 2 audios. But when i recieve them over SDI it is embedded 2 channel audio not 4 channels.
I am using M and bus A and I have Decklink 4k Extreme 12G.
Any advise?
Thanks.
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Yes, SRT output sends 4ch embedded audio, but SDI output is set to only 2 channel audio. Is it possible to set externel output to 4ch embedded audio?
iit seems, that the forum is being flooded more and more by bots, which is likely preventing newcomers from receiving assistance in the future. it would be nice, if vMix would making it a bit more challenging for bots to sign up for the forum. i have fallen for another entry once again.
 431052092_414603757826617_3232424720601278142_n.png (24kb) downloaded 1 time(s). 431751301_1726503081210535_6816489669092325650_n.jpg (473kb) downloaded 1 time(s). 432797530_951244319954796_3091511468382826827_n.png (1,056kb) downloaded 1 time(s).Hello Peter, thank you very much for replying my question. If you see this post again, as you can see at those screenshots, SRT has 4ch but external output on SDI has only 2ch.
If you Google your BM Card Features, the Card has 8ch embedded audio. The XLR analog Breaking has only 2ch. Are you using a SDI disembedder?
BM card has up to 16 ch embedded audio on SDI. Yeah, SDI de-embedder. idk, Vmix has no support on 4ch embedded audio?
Thanks: 64 times Was thanked: 160 time(s) in 144 post(s)
Have you actually followed the advice given by Peter on the linked website?
