Michael7687
#1 Posted : Thursday, February 29, 2024 1:24:04 PM(UTC)
Michael7687
I don't think this is a Vmix problem but it is affecting my Vmix audio Outputs.I am sure there is probably a simple solution, but for the life of me I can't figure out what it is... I am getting two audio feeds into the same monitor at the same time.Any Suggestions from you Computer experts?
dmwkr
#2 Posted : Thursday, February 29, 2024 8:40:43 PM(UTC)
dmwkr
Does it also happen when playing audio from another software on the vMix PC? How is the monitor connected? What are your Audio Output settings in vMix?
ovonder
#3 Posted : Thursday, February 29, 2024 10:10:43 PM(UTC)
ovonder
Try turning of the headphone volume (to 0) in the audio mixer master settings.
I have had "echo" issues which were caused by custom audio output settings, causing both the headphone and master going to the same audio output.
The master output had a slide delay causing an echo effect.
