Feature Requests
Customize jog and shuttle on ShuttlePro
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
How the shuttle wheel (the external ring) works in the replay seems to me a waste: only the replay playback speed changes
Through the contour software I was able to associate shortcuts that include alt + mousewheel up and down. In this way in the replay interface it is more natural to move back and forward without using jogwheel.
Except that vMix still interprets the change in playback speed. The only way to avoid this is to launch vmix without the ShuttlePro and connect it later (losing the ability to use its keys)
So I ask if it is possible for us to customize jogwheel functions from the "Shortcuts" panel as we can customize the buttons
 1 user thanked Torg for this useful post.
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
+1, would also love to use it for other stuff, such as zooming with a PTZ.
+1
To me its not intuitive to have it do speed, compared to other industry standard similar controllers. having it be a faster rewind (shuttle) is more in line with industry standard for dual wheel controllers like this. The jog in the middle is perfect, but ability to customize would let it be like the other controllers in vMix.
 1 user thanked spencerm24 for this useful post.
Joined: 5/3/2019(UTC) Posts: 11   Location: Seattle Thanks: 7 times
Joined: 6/5/2019(UTC) Posts: 29  Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
+1
or ... maybe a checkbox to switch between replay-speed and forward / backward on the frame position scrollbar.
JimJim XUN
JimJim XUN
+1 I think the checkbox is a good idea !! :)
Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
+1 Yes please add this!!!
Joined: 6/1/2020(UTC) Posts: 27  Location: Spain Thanks: 1 times Was thanked: 7 time(s) in 4 post(s)
Any updates on this? Thanks
Old Thred update
V27 and shuttle driver 2.13.5 was able to directly control direction and speed using replayFastForward and Backward within the various position steps in vMix. just needed an extra shortcut (in vMix) to make it pause when released called from the shuttle configuration (when centered) itself
Disable the speed shortcut for it
Feature Requests
