Joined: 12/23/2018(UTC) Posts: 120   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
hi im new in UTC i want to have the BUTTON RED (for exemple) when i clic on it and the OVERLAY is ON LINE. and Yellow (for exemple) if NOT. what i have to do please?  xzxz.JPG (8kb) downloaded 3 time(s). asa.JPG (34kb) downloaded 4 time(s).i want to have the state ON when this layer is ON  pen.JPG (24kb) downloaded 2 time(s).
Joined: 6/29/2011(UTC) Posts: 313   Location: Florida Thanks: 6 times Was thanked: 33 time(s) in 32 post(s)
I'm not a UTC user, but with my streamdeck controller to trigger changes. I've created a text circle from Character Map i.e. (●) and adjust font size in GT and use the "Set TextColor" command to change to desired color using HEX color code or type basic color name such as Red
Joined: 12/27/2012(UTC) Posts: 5,470  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
Originally Posted by: Egriswold  I'm not a UTC user, but with my streamdeck controller to trigger changes. I've created a text circle from Character Map i.e. (●) and adjust font size in GT and use the "Set TextColor" command to change to desired color using HEX color code or type basic color name such as Red One can changes colors of shapes now too with a shortcut !!
Joined: 11/27/2017(UTC) Posts: 17   Location: Louisville, Kentucky Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
 State Dependent.png (63kb) downloaded 3 time(s).Make sure the state dependent box is checked.
