Joined: 11/14/2012(UTC) Posts: 356  Location: Finland Thanks: 222 times Was thanked: 23 time(s) in 21 post(s)
Now there is only 2(!) recording outputs?
User should be able record any amount outputs or at least 4 that can now be configured in Settings.
Multicorder does not work for you??? If not, why? (search to forum and KB for tips)
Originally Posted by: richardgatarski  Multicorder does not work for you??? If not, why? (search to forum and KB for tips) Multicorder does NOT directly support recording of ANY other type of input source than video camera/player, or does it?
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: jet  Originally Posted by: richardgatarski  Multicorder does not work for you??? If not, why? (search to forum and KB for tips) Multicorder does NOT directly support recording of ANY other type of input source than video camera/player, or does it? outputs 1-4, SRT Inputs, NDI Inputs
Thanks Doggy! I will try them out!
Joined: 10/31/2020(UTC) Posts: 197  Thanks: 5 times Was thanked: 44 time(s) in 43 post(s)
I've had horrible stability issues when using multicorder with Outputs. I now only use it with actual camera inputs, and now get perfect stability.
Originally Posted by: kross  I've had horrible stability issues when using multicorder with Outputs. I now only use it with actual camera inputs, and now get perfect stability.
Please all vote this feature: MultiCorder and Record button should blink if MultiCorder (/Record) is dropping frames!https://forums.vmix.com/...nking-MultiCorder-button...if your recordings/projects are any precious to you...
