VMix Zoom Audio permanently on Solo
Joined: 5/9/2020(UTC) Posts: 18  Location: Cologne Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
I have a simple show setup today with a couple of NDI inputs and one Zoom input. I have noticed that the Zoom input is audible thru solo, although not turned on at all. It can be heard at normal volume, as if soloed. Hardware setup is a SSL 2+ interface with Asio driver. Main Output routed to 1/2 and Solo routed to 3/4. VMix is 27.0.0.69. Does anybody have the same experience?
Also I noticed that PFL on a list with a couple of mp3s did not work, although mentioned as fixed in the changelog.
