#1 Posted : Monday, January 22, 2024 12:45:07 PM(UTC)
27.0.0.61
Initial release
* Fix for missing participant leaving/joining messages in Zoom
thanks 10 users thanked admin for this useful post.
QuiapoChurch on 1/22/2024(UTC), jet on 1/22/2024(UTC), STADIORADIO on 1/22/2024(UTC), sam602 on 1/23/2024(UTC), raugert on 1/24/2024(UTC), stigaard on 1/24/2024(UTC), eduardocfs on 1/28/2024(UTC), avsoundguy on 1/30/2024(UTC), orbison30 on 4/28/2024(UTC), amahina on 5/19/2024(UTC)
#2 Posted : Wednesday, January 24, 2024 1:46:31 PM(UTC)
27.0.0.62
* Fixed issue with changing vMix Call Audio Source to a bus when the buses in between are disabled (set to None).
* Fixed Zoom input going offline when the latest Zoom plugin is not installed.
thanks 5 users thanked admin for this useful post.
jet on 1/25/2024(UTC), migueldbm on 1/25/2024(UTC), eduardocfs on 1/28/2024(UTC), avsoundguy on 1/30/2024(UTC), stigaard on 4/26/2024(UTC)
#3 Posted : Thursday, January 25, 2024 8:19:11 PM(UTC)
27.0.0.63
* Fixed error on startup when language set to Korean
QuiapoChurch on 1/26/2024(UTC), skyemedia on 1/28/2024(UTC), eduardocfs on 1/28/2024(UTC), avsoundguy on 1/30/2024(UTC), stigaard on 12/21/2024(UTC)
#4 Posted : Sunday, January 28, 2024 7:15:57 PM(UTC)
27.0.0.64
* Fix for UWPInterop.dll crash in Desktop Capture "WindowsGraphicsCapture" when selecting some invalid windows that may appear in the list on some systems.
* Big improvements in performance when handling very large numbers of participants in Zoom meetings
vMix does this by reducing the number of notifications when a large number of participants join at once and optimising the menus and lists showing all the participants
* Fix for vMix Social settings from 26 not migrating over to 27
* Zoom meetings can now be disconnected while the connection is still in progress
* Some forms of Zoom Webinars may now work in vMix as long as the following are true:
1. The vMix participant is promoted to Panelist by the Webinar host. (vMix will show as "connecting" until the promotion occurs)
2. The Webinar operates in Zoom Meeting mode. "Events" are not supported.
Thanks to Dean from 5by5.ca for his assistance!
thanks 9 users thanked admin for this useful post.
Simsyuk on 1/28/2024(UTC), raugert on 1/29/2024(UTC), eduardocfs on 1/29/2024(UTC), Mano Bakker on 1/29/2024(UTC), Hitman007 on 1/30/2024(UTC), avsoundguy on 1/30/2024(UTC), Peter Berglund on 1/30/2024(UTC), jet on 1/31/2024(UTC), stigaard on 12/21/2024(UTC)
#5 Posted : Wednesday, January 31, 2024 1:21:56 PM(UTC)
27.0.0.65
* Fix for error on new preset window when using older Basic and SD editions
* Fix for missing Zoom Meetings with no start time in the dropdown list
monamiga on 1/31/2024(UTC), jet on 1/31/2024(UTC), spinfold on 1/31/2024(UTC), avsoundguy on 2/1/2024(UTC), eduardocfs on 2/14/2024(UTC)
#6 Posted : Thursday, February 1, 2024 3:29:54 PM(UTC)
27.0.0.66
* Improved isolation to prevent a crash in Zoom SDK from crashing vMix
* Fix for Streaming Use Hardware Encoder not displaying on Windows systems with Turkish language set
* Added back Mouse Wheel for Audio Mixer faders
jet on 2/1/2024(UTC), Simsyuk on 2/2/2024(UTC), carmelo on 2/2/2024(UTC), Hitman007 on 2/2/2024(UTC), eduardocfs on 2/14/2024(UTC)
#7 Posted : Tuesday, February 6, 2024 6:15:06 PM(UTC)
27.0.0.68
* Fix for error when resetting Stream RTSP input when a reconnection is already in progress
* Fix for crash when opening AVI files in MJPG format
* Fix for SetVolumeFade not updating API XML and Activator InputVolume values
jet on 2/6/2024(UTC), QuiapoChurch on 2/6/2024(UTC), Acid on 2/7/2024(UTC), Chircanu on 2/9/2024(UTC), eduardocfs on 2/14/2024(UTC)
#8 Posted : Tuesday, February 13, 2024 1:23:53 PM(UTC)
27.0.0.69
* Fix for PFL not working for List inputs
* Fix for line flicker that can occur on corners of borders during some merges
* Meters Pre-Fader checkbox added to settings to make default for new inputs
New Zoom Plugin
A new optional update to the Zoom Plugin is available at the page below:
https://www.vmix.com/zoomplugindownload/
This fixes an issue using Streaming Capture Mode when local recording is enabled on the meeting settings.
QuiapoChurch on 2/13/2024(UTC), Simsyuk on 2/13/2024(UTC), eduardocfs on 2/14/2024(UTC), Hitman007 on 2/14/2024(UTC), raugert on 2/14/2024(UTC), jet on 2/14/2024(UTC), ask on 2/19/2024(UTC), fgolman on 2/25/2024(UTC), stigaard on 4/11/2024(UTC), vishwa.prakash on 6/13/2024(UTC)
#9 Posted : Tuesday, March 26, 2024 4:26:03 PM(UTC)
27.0.0.72
* Fixed issue with loading some VST3 plugins that use duplicate names
* Fixed issue with *LayerAnimated shortcuts on Virtual Set, Photos and GT inputs
* A camera input configured as PsF will now record as progressive in MultiCorder instead of maintaining interlaceed.
* Performance improvements for Zoom to allow Webinars of up to 2000 participants.
(The right click Participant Source menu will now be limited to the first 100 participants, for all other participants the list in Zoom Manager can be used)
* Fixes for some icons and elements on high DPI displays set to 200% scaling or more.
* If Recording Setup is accidentally left open when starting recording, clicking OK may stop recording. Recording Setup window now automatically closed when starting recording to avoid this.
thanks 8 users thanked admin for this useful post.
monamiga on 3/26/2024(UTC), jet on 3/27/2024(UTC), vishwa.prakash on 3/27/2024(UTC), sam602 on 3/29/2024(UTC), stigaard on 3/30/2024(UTC), Peter Berglund on 4/3/2024(UTC), tridenator on 4/10/2024(UTC), eduardocfs on 6/30/2024(UTC)
#10 Posted : Wednesday, April 24, 2024 4:36:45 PM(UTC)
27.0.0.75
* NEW Zoom shortcuts:
ZoomMuteSelf
ZoomUnMuteSelf
ZoomSelectParticipantByName
* NEW Zoom input Meeting Settings menu now has option to Mute/UnMute self. This controls the audio Zoom sends from vMix to other participants.
(Note Zoom updates require the latest Zoom plugin to be installed from https://www.vmix.com/zoomplugindownload/
vMix will not always prompt for Zoom plugin updates unless a bug has been fixed or a Zoom enforced security update has been applied)
* Fixed SetGammaY shortcuts not working correctly
* Fixed missing audio at the end of Replay MP4 exports
* Fixed documentation incorrectly stating SelectedValue instead of SelectedName for some shortcuts
* Fixed issue where Zoom chat was not showing up until Zoom Manager window opened
thanks 14 users thanked admin for this useful post.
richardgatarski on 4/24/2024(UTC), jet on 4/24/2024(UTC), RichDanby on 4/24/2024(UTC), raugert on 4/25/2024(UTC), Chircanu on 4/25/2024(UTC), sinc747 on 4/25/2024(UTC), Simsyuk on 4/25/2024(UTC), QuiapoChurch on 4/25/2024(UTC), WaltG12 on 4/25/2024(UTC), stigaard on 4/26/2024(UTC), spinfold on 4/27/2024(UTC), vishwa.prakash on 5/1/2024(UTC), knbPixels on 5/2/2024(UTC), eduardocfs on 6/30/2024(UTC)
#11 Posted : Monday, May 13, 2024 4:32:54 PM(UTC)
27.0.0.76
* VLC input audio converter quality improvement
* Fix for MultiCorder setting incorrect audio bus for "Master" audio when previously recording Outputs set to a different audio buses.
* Fix for vMix sometimes not properly muting audio of Zoom call on systems with multiple audio outputs
tsioukas on 5/13/2024(UTC), jet on 5/13/2024(UTC), Simsyuk on 5/14/2024(UTC), monamiga on 5/14/2024(UTC), stigaard on 5/17/2024(UTC), emet on 5/20/2024(UTC), raugert on 5/23/2024(UTC), AngusFindlay on 6/11/2024(UTC), vishwa.prakash on 6/13/2024(UTC), eduardocfs on 6/30/2024(UTC)
#12 Posted : Sunday, June 23, 2024 8:53:09 PM(UTC)
27.0.0.81
* Updated Zoom to latest version (6.0.11). This requires installing the latest Zoom plugin from https://www.vmix.com/zoomplugindownload
* Renaming participants in Zoom will now show the updated names in vMix. vMix will continue to use the original names behind the scenes and in presets for tracking purposes.
* Added support for selecting a Language stream in a Zoom meeting. Note this may mute audio from participants who are not part of that language.
* Fix for vMix not closing RTMP streams after a crash
* OnCompleted trigger will now work in layers of output in addition to the main input
* Updated javascript libraries in vMix Social and Web Controller web pages
* Fixed issue with DPI scaling not working correctly
* Improved Zoom audio performance by increasing buffers
thanks 15 users thanked admin for this useful post.
gpdipalmerahtimur on 6/23/2024(UTC), tsioukas on 6/23/2024(UTC), jet on 6/23/2024(UTC), raugert on 6/24/2024(UTC), clafarge on 6/24/2024(UTC), monamiga on 6/24/2024(UTC), Simsyuk on 6/24/2024(UTC), richardgatarski on 6/24/2024(UTC), stevespaw on 6/25/2024(UTC), MW-Music on 6/27/2024(UTC), eduardocfs on 6/30/2024(UTC), vishwa.prakash on 7/1/2024(UTC), Fatih_Demirsoy on 9/18/2024(UTC), ron2210 on 10/1/2024(UTC), stigaard on 12/21/2024(UTC)
#13 Posted : Monday, September 2, 2024 1:48:32 PM(UTC)
27.0.0.83
* Fixed vMix AVI length longer than expected when exporting multi-channel audio from vMix Replay
* Fixed incorrect scaling on Language selection window
* Fixed rare Zoom errors
* Fixed error when browsing for a LUT when the previously used folder no longer exists
eduardocfs on 9/2/2024(UTC), tsioukas on 9/2/2024(UTC), Chircanu on 9/2/2024(UTC), Luis70 on 9/3/2024(UTC), monamiga on 9/3/2024(UTC), QuiapoChurch on 9/10/2024(UTC), Fatih_Demirsoy on 9/18/2024(UTC), jet on 9/24/2024(UTC), stigaard on 12/21/2024(UTC)
#14 Posted : Sunday, September 29, 2024 4:43:00 PM(UTC)
27.0.0.84
* Fix for Replay A|B button causing second camera angle to get stuck when pressed twice
* Fix for Replay auto-delete not always deleting older segments
* Fix for Replay export audio sync drift when exporting a lot of events together
* Workarounds for some VST3 plugin that do not support High-DPI displays correctly
thanks 6 users thanked admin for this useful post.
jet on 9/29/2024(UTC), raugert on 9/29/2024(UTC), monamiga on 9/30/2024(UTC), eduardocfs on 9/30/2024(UTC), QuiapoChurch on 9/30/2024(UTC), stigaard on 12/21/2024(UTC)
#15 Posted : Sunday, October 6, 2024 5:49:03 PM(UTC)
27.0.0.85
* YouTube now mandating that Description be required in streaming settings.
* Buses CDEFG missing from Default Audio Bus setting
thanks 7 users thanked admin for this useful post.
raugert on 10/7/2024(UTC), Peter1000 on 10/7/2024(UTC), ron2210 on 10/7/2024(UTC), monamiga on 10/7/2024(UTC), eduardocfs on 10/8/2024(UTC), jet on 10/8/2024(UTC), stigaard on 11/15/2024(UTC)
#16 Posted : Thursday, October 24, 2024 1:59:33 PM(UTC)
27.0.0.86
* Updated GT Designer PSD Import to support latest Photoshop update
monamiga on 10/24/2024(UTC), jet on 10/24/2024(UTC), QuiapoChurch on 10/24/2024(UTC), eduardocfs on 10/29/2024(UTC), stigaard on 11/15/2024(UTC)
#17 Posted : Monday, October 28, 2024 12:54:19 AM(UTC)
27.0.0.87
* Fix for multiple line YouTube Live Stream Now description not displaying correctly
* Fix for quotation marks in YouTube Live Stream Now title causing error
Hitman007 on 10/28/2024(UTC), monamiga on 10/28/2024(UTC), eduardocfs on 10/29/2024(UTC), Simsyuk on 10/30/2024(UTC), jet on 10/30/2024(UTC), stigaard on 11/15/2024(UTC)
#18 Posted : Tuesday, October 29, 2024 10:14:24 PM(UTC)
27.0.0.88
* Added workaround to fix colour distortion in vMix Call inputs due to a bug in recent Intel Iris Xe graphics drivers.
monamiga on 10/29/2024(UTC), Chircanu on 10/30/2024(UTC), jet on 10/30/2024(UTC), Edy Santos on 11/5/2024(UTC), eduardocfs on 11/13/2024(UTC), stigaard on 11/15/2024(UTC)
#19 Posted : Sunday, December 1, 2024 6:12:03 PM(UTC)
27.0.0.89
* Fix for Decklink inputs not working after latest driver update (14.3)
jet on 12/1/2024(UTC), raugert on 12/2/2024(UTC), sinc747 on 12/12/2024(UTC), stigaard on 12/21/2024(UTC), eduardocfs on 1/20/2025(UTC)
#20 Posted : Sunday, January 19, 2025 6:43:20 PM(UTC)
27.0.0.90
* Fix for vMix Call issue with Google Chrome 132
thanks 4 users thanked admin for this useful post.
jet on 1/19/2025(UTC), eduardocfs on 1/20/2025(UTC), sinc747 on 1/20/2025(UTC), stigaard on 1/21/2025(UTC)
Guest (11)
