Kona 4 analog audio output while using capture sped up
Joined: 2/21/2023(UTC) Posts: 11  Location: Minnesota Thanks: 6 times
I have a simple setup on one of my machines where I take SDI in with embedded audio using a Kona 4 to capture, add graphics in vMix, and use the external output to send the dirty video and audio back out of the Kona 4. When I first start my known good preset, analog audio sounds like Alvin and the Chipmunks are on mic. If I change any setting in the Audio Output settings and restart vMix, the analog audio is normal. But, anytime I restart again, analog audio is corrupt again. Embedded SDI audio is always just fine. I have experimented with various windows settings and Aja Control panels settings, but the result is the same. Has anyone seen this and found a solution? Thanks much!!
Bill
