Instant Replay
Works / Changing Stingers used for playing Instant Replay events
An old question is how to change the stingers used for playing events on the fly
This works
As Example have 2 stinger inputs (example Stinger 3- Slatz Red- No Logo.gtzip and Stinger 1- Liney Blue- No Logo.gtzip) Create 2 shortcut SetDynamicInput1 with value 1st stinger input and SetDynamicInput1 with value 2nd stinger for selecting a stinger (Perfom at least one before continuing) Add a Transparent input and give it a few triggers - OnOverlayIn : function= OverlayInput1 , Input- Dynamic1 - OnOverlayIn : function= OverlayInput1 , Input- Dynamic1, Delay= 1000 In Overlay settings Specify Stinger 1 to be your transparent input (effect dur,duration,cutpoint set at 1000, might have to play with the timing depending on the stingers used) Specify in Instant replay your In (and/or Out) Transition as Stinger 1
Change the wanted stinger to be used with your shortcuts for playing events
Play your events
Instant Replay
