Hi! With 8 vmix calls often used in addition to external equipment, recording and mixer, is it possible to increase the number of external audio outputs? It happens that I have to have more than 2 vmix calls on the same output and that causes me problems on the air (eg: I have to speak to a speaker who has just connected while the other person is already on the air)
Thank You!
@ Jef Berard (QUB) Do you mean a talk-back channel as explained in this video: Ice
Thanks but no, I already do that and it works well. :) For exemple : M = recording / streaming A = to TV mixer B to G = 6 outputs remaining for my 8 vmix calls or externals, it's too little for my needs.
(we are live on television and radio 12h a day, this requires preparation in advance without impacting the channels already used)
Joined: 1/23/2022(UTC) Posts: 131  Location: Milton Keynes Thanks: 14 times Was thanked: 14 time(s) in 14 post(s)
Originally Posted by: Jef Berard (QUB)  Thanks but no, I already do that and it works well. :) For exemple : M = recording / streaming A = to TV mixer B to G = 6 outputs remaining for my 8 vmix calls or externals, it's too little for my needs.
(we are live on television and radio 12h a day, this requires preparation in advance without impacting the channels already used) Why do you need a bus per caller? vMix handles MixMinus internally so you don't need to worry about giving a dedicated bus to each caller unless there is something unique you're doing which requires each caller to have a separate audio feed? While I agree that vmix needs more audio buses, you don't need to use it in the way it appears you are.
We are a live channel with nearly 60 guests or columnists per day, so while an interview is in progress, sometimes the tv manager must communicate with a guest who connects to vmix call to test certain things without disturbing the interview in progress.
Thanks: 4 times Was thanked: 20 time(s) in 19 post(s)
its not the most elegant option but the busses are stereo you should be able to use two mono sources per buss.. which is 12 outputs..
Originally Posted by: Jef Berard (QUB)  We are a live channel with nearly 60 guests or columnists per day, so while an interview is in progress, sometimes the tv manager must communicate with a guest who connects to vmix call to test certain things without disturbing the interview in progress. Is there a reason you can't have a dedicated audio bus for your talkback microphone (say Bus B) and then switch the caller's audio source to Bus B on press, and back to Main on release, of a Streamdeck button?
