v27.0.0.68 zoom audio issues
Joined: 9/30/2020(UTC) Posts: 56  Location: Manchester Thanks: 10 times Was thanked: 3 time(s) in 3 post(s)
Hi - We were trying out the new zoom embedded in vmix for the first time. Something is not right.
It appears that all of the zoom audio output is getting routed to our busA and busB even though those busses are disabled for the zoom input channel. Furthermore, audio is getting routed to those busses even when the zoom input channel is muted, and even when the zoon input channel is not active, that is, not showing on the preview screen nor the output screen.
It seems like zoom audio should be completely controlled just like any other audio source. Have we found a bug in vMix? Or do we have something configured incorrectly?
Joined: 1/23/2022(UTC) Posts: 132  Location: Milton Keynes Thanks: 14 times Was thanked: 14 time(s) in 14 post(s)
Although I don't have that version and haven't seen the issue first hand, based on what you've said it's a bug.
There was a big early on in development where no Zoom audio would be heard at all if Bus C or higher was enabled. So sounds very similar to that.
