krushd
#1 Posted : Monday, December 25, 2023 1:08:34 AM(UTC)
krushd
Added push button talkback to the latest install and while it will switch audio return for a vMix Caller to a different bus (BusG) initially, it will not return to master. After some initial testing, there doesn't seem to be a way to get it back on master without starting a new connection. Feedback will show the bus as changed back to master, but the audio sending will still be BusG.
The same process works on vMix 26 just fine.
The basic steps in this were followed for creation of talkback: https://www.vmix.com/kno...n-talkback-for-vmix-call
#2 Posted : Wednesday, December 27, 2023 1:45:36 AM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
I have moved this to vMix Call discussion, as we are not able to replicate this, switching between Master and the audio busses and then back again works as expected
in the latest vMix 27 beta.
There is likely something different in your setup that is not working as expected I would suggest sending a support report and contacting us:
https://www.vmix.com/contact-us.aspx
h2video.nl
#3 Posted : Sunday, February 4, 2024 9:08:10 PM(UTC)
h2video.nl
I had a similar issue like this: the main mic would not switch to BusG although tested as described. It used to before but after a recent update it stopped.
Check everything but...
Plus: is there a way to separate / eliminate the audio from the studio not to be heard over the ear phones (or: how do you set up the mix minus for the one puch button call back...).
cheers
Stefan
