It would be nice to add the zoom caller title to the input. That way we are not needing to add them in manually. Perhaps look at also adding this to the data sources so that we can manipulate the display using the GT titles etc (in addition to the zoomchat).
There maybe some benefit to adding this information to be retrieved via triggers.
Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
+1, if, and only IF, it is an option.
Joined: 2/14/2024(UTC) Posts: 9  Location: Liverpool Thanks: 1 times
Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
Very much needed, +1.
Should be like most other sources, the name on the preview and elsewhere should look like:
1 Zoom (Bob)
And then also appear elsewhere (EG, layer names).
Thank you!
Fritz Golman iHeartMedia
Originally Posted by: fgolman  Very much needed, +1. Should be like most other sources, the name on the preview and elsewhere should look like: 1 Zoom (Bob) And then also appear elsewhere (EG, layer names). Thank you! Fritz Golman iHeartMedia I would actually prefer it in a similar fashion as for Virtual and List inputs, with the assigned Input name. For example, with the participant "Richard Gatarski" in an Input named "Link A", this would be shown in vMix's Main window: Quote:Richard Gatarski - Link A And, accordingly, have the API content as: Quote:Title="Richard Gatarski - Link A" ShortTitle="Link A" That would allow us to conveniently have the info with the Inputs preview, and more importantly use the ShortTitle for shortcuts and scripts. That is, the ShortTitle will remain the same even if the participants name has changed. Hoping... /richard
