After V27 Update, Can only stream to one key *resolved*
Joined: 4/15/2022(UTC) Posts: 18  Location: Maryland Thanks: 1 times
After V27 Update, Can only stream to one key! HELP!
Tried starting manually as well and Stream 2 will NOT start.
Has anyone experienced this yet?
Hello. No problem for me with 27.0.0.63. I can stream 1 and 2 like before
I am using 27.0.0.63.
I have since tried several things. I switched between YT Live and YT Stream Now and back to YT Live and now it appears to work now
Was odd that neither worked, even manually and then it did.
I have not updated to 27.0.0.64
BUT THE SOLUTION to my problems, which I hope someone else can emulate and Vmix fixes is:
I have two YouTube streams setup for streams 1 and 2: (2 different keys)
When I push Stream to start stream, stream 1 starts fine.
THE FIX FOR ME is to be right on top of the starting stream and click Stream 2. CLICK something OTHER THAN YOUTUBE Live THEN Click YOUTUBE LIVE again and the Stream 2 button is now available for click(ing). Click Stream 2 and it works..... very inconvenient. (Prior to manually clicking Stream 2, the Button is unavailable)
