ArunLongjam
#1 Posted : Sunday, January 14, 2024 4:26:12 AM(UTC)
ArunLongjam
India
Hi guys, I have two inputs, first one is 5mins long video and the second one is image sequence. Later I put my video inside image sequence's layers/Multi View. I apply image sequence input to stinger1. I want every time I play stinger1 my video play continuously instead of restarting from the beginning. I check 'loop' in input1 video and turn off 'Automatically Play with Transition' and 'Automatically Restart with Transition' in both input. How can I stop restarting my video while playing stinger1? Thanks.
#2 Posted : Sunday, January 14, 2024 7:49:31 AM(UTC)
@ ArunLongjam
Can you clarify what you are trying to accomplish?
If I understand you correctly, embedding a video into a MultiView Layer of an Image Sequence Stinger transition will always play automatically from the beginning regardless of whether or not "Automatically Play with Transition" or "Automatically Restart with Transition" is turned on or off.
You would be better to use Triggers with your Stinger to Overlay your Video that you have playing on a loop perpetually.
Luis70
#3 Posted : Sunday, January 14, 2024 8:13:58 AM(UTC)
Luis70
Grenada
Untick "Automatically Restart with Transition"
ArunLongjam
#4 Posted : Sunday, January 14, 2024 11:39:35 AM(UTC)
ArunLongjam
India
Originally Posted by: IceStream Go to Quoted Post
@ ArunLongjam
You understand correctly, I'll try with triggers. Thank you👍👍
ArunLongjam
#5 Posted : Thursday, January 18, 2024 2:50:41 PM(UTC)
ArunLongjam
India
@ ArunLongjam
Hi @Ice, I tried, but it's not working for me. Stinger always on top layer(hide everything behind it). In the given image below, I want my ticker input to overlay1 every time I play stinger1. Thanks.
#6 Posted : Thursday, January 18, 2024 8:02:52 PM(UTC)
Maybe this could help
Screenshot 2024-01-18 110016.jpg (57kb) downloaded 0 time(s).
ArunLongjam
#7 Posted : Friday, January 19, 2024 3:48:24 PM(UTC)
ArunLongjam
India
Thank you doggy. It's working👍
