Systems
My configuration - is it ok?
Asus PROART Z790-CREATOR WIFI Intel Core i9-14900K ARCTIC Liquid Freezer II 360 Kingston FURY 64GB (2x32GB) 5600MHz CL40 Beast Black PNY 1TB M.2 PCIe Gen4 NVMe XLR8 CS3140 DeepCool PX1000G PNY GeForce RTX 4080 Verto 16GB GDDR6X Fractal Design Pop XL Silent Solid
Eelgato Cam Link Pro BlackMagic Decklink 8K
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
Witch motherboard do you recommend?
@ arszu To use two or more capture cards, vMix recommends the older X-Series i9 CPUs on an X299 Motherboard as per the Obsidian and Diamond Reference Systems, but you could also use current AMD Threadripper Pro CPUs. Ice
Systems
