Feature Requests
Slicker access to Web Interface/API
Currently (v13) the Web Interface is at least four clicks away before it can be used. The first click is on the "View shortcuts", then a second click in it's pop up window on the "Web Interface" button. Third click goes to closing the shortcut window. And, finally, the fourth click is needed to select the desired function, for example "Controller". Maybe vMix's bottom row "Controller" could be shrunken to an icon. This would create room for icons for "Shortcuts" (vMix popup window), and "Controller" and "Titles" (corresponding browser pages). (Tally is meaningless on the vMix PC). Sometimes I access the Web Interface only as a way to find out the IP and port number, which is necessary to know for remote API control and/or Tally functionality. It would be very nice if the balloon tooltips for "View shortcuts", or even better the icons suggested above ;), also displayed the PC's web address for API access. Ideally vMix would have some kind of auto discovery mechanism for remote access. But maybe that's complicated to implement. And definitely not a good idea until there is some kind of Web control rights are implemented. Thanks in advance for any comments.
Feature Requests
