sunkast
#1 Posted : Tuesday, December 19, 2023 12:55:43 PM(UTC)
sunkast
Wondering if anyone has any insight between these 2 GPUs. Would I be better off getting a used RTX 3090 due to it's increase in CUDA cores and memory over an RTX 4070 TI? Does vMix benefit from a higher memory and CUDA cores?
RTX 3090 has 10496 CUDA cores and 24 GB of memory.
RTX 4070 TI has 7680 CUDA cores and 12 GB of memory.
paco3346
#2 Posted : Friday, January 12, 2024 7:39:34 AM(UTC)
paco3346
CUDA cores is the single most important thing in terms of vMix. Go for the highest option you can.
AuditorRSTO
#3 Posted : Monday, January 15, 2024 6:28:36 PM(UTC)
AuditorRSTO
Germany
The new option of encoding in AV1 codec is only possible with Geforce Series RTX 40 and following.
