TL68
#1 Posted : Wednesday, January 10, 2024 10:39:03 PM(UTC)
TL68
Sweden
Hi!
Afaik there is only a ReplayShowHide toggle avalayble to show and hide the Replay panel with a shortcut or API command.
For our setup it would be really helpful to be able to hav separade commands for Show and Hide so I would welcome the inclusion of two new commands which would be:
ReplayShow
ReplayHide
Use case is when you want to group a number commands on for example a streamdeck button to get the vMix session in the right mode, like the right inputs in pgm/prv, start recording, etc etc
Here the current toggle function sometimes hides the replay panel regarding what else is going in in the interface. So sometimes two presses is necessary to get vMix in the right mode and sometimes one press. All depending on whether the replay panel is visible or not when the button is pressed for the first time.
So this grouped button would work better if the command was ReplayShow instead of the toggle.
Hope I managed to explain what I mean :-).
