sdonn
#1 Posted : Thursday, January 4, 2024 3:14:28 AM(UTC)
sdonn
I want to be able to stop users from using keyboard shortcut during a session. I use Vmix within a photobooth. Once the photo sequence is activated, I want the shortcut to deactivate until the end of the photobooth sequence. It would be ideal for Vmix to have a function like 'Ontransition in, Stop Shortcut A"
This would prevent people from interrupting the photobooth sequence in the middle.
I have searched I can't see a way to do this currently.
#2 Posted : Thursday, January 4, 2024 3:39:27 AM(UTC)
you could tie the shortcut to a script that reads a dynamic value for the logic to either perform or not the intended function.
The trigger could then be used to change the dynamic value (for on/off setting of the intended function)
sdonn on 1/4/2024(UTC)
sdonn
#3 Posted : Thursday, January 4, 2024 4:19:51 AM(UTC)
sdonn
Thanks for a possible solution... A little beyond my technical expertise :-)
nikosman88
#4 Posted : Thursday, January 4, 2024 4:59:20 AM(UTC)
nikosman88
Greece
Hello. In theory if one want to do something in vmix or in the pc when must not, he can do. He can push something that will damage the whole show.. Other than that i believe that alternative way to do this if you are not familiar with scripting is via bitfocus companion using the internal value change.
sdonn
#5 Posted : Saturday, January 6, 2024 8:39:07 PM(UTC)
sdonn
Bitfocus seems like a faff. Think this would only work for me if it was built into Vmix.
