chrisw734@gmail.com
#1 Posted : Thursday, December 21, 2023 7:27:54 PM(UTC)
chrisw734@gmail.com
The audio bus manager is a great addition to vMix 27, very much appreciated. It would be great to see the user assigned bus labels along the top of the audio bus manager, as well as the bus letter label, especially for those more complicated audio projects, to ensure the routing you are selecting is correct.
Thank you again for your continued hard work on the vMix software.
thanks 1 user thanked chrisw734@gmail.com for this useful post.
TBacker on 9/4/2024(UTC)
TBacker
#2 Posted : Wednesday, September 4, 2024 12:13:22 PM(UTC)
TBacker
+100
The bus column headers don't need to be that wide or tall to accmodate names if the text is run vertically (aka top to bottom instead of left to right). Same as if a bus master is minimized in the mix window.
May I add...
- A bus manager button in the audio tab / mix window for quicker access. Profiles with busy / frequent routing changes should have a single click, clear way to show the matrix.
- Auto-resize the bus manager window to fit the number of I/O crosspoints. Only resort to scroll bars if it nears full screen size.
- Remember the position of the bus manager window.
- Add a "Show in bus manager" check box in individual source input configurations to allow selecting/hiding. Sometimes not all input's bus assignments should be available. Or just hide inputs not visible in the mix window.
YBS
#3 Posted : Tuesday, September 24, 2024 6:52:44 AM(UTC)
YBS
Antigua and Barbuda
