fabfab10
#1 Posted : Tuesday, December 19, 2023 7:51:29 PM(UTC)
fabfab10
Italy
Hello, i would like to know if anyone is successfully using a Dante Stagebox, like "8 in - 8 out", in order to have multiple remote I/O on a single network cable.
If so please share you brand device and configuration.
Maximus
#2 Posted : Wednesday, December 20, 2023 11:14:06 PM(UTC)
Maximus
Hi, I use a Yamaha Tio1608 D 16 in 8 out. I believe there us a new version Tio1608 D2, but I am not sure what the difference is between the two. Although it is a Yamaha product and does have direct interface with some of their mixers, it can be used solely as a Dante interface. So far i have had no challenges in use. At around 1250.00, it is probably the most cost effective device on the market for Dante i/o
Maxi
fabfab10
#3 Posted : Thursday, December 21, 2023 12:02:24 AM(UTC)
fabfab10
Italy
AFAIK version D2 should have sampling rate up to 96kHz, input to output delay less than 1.3 ms instead of 3ms for D version, and compatibility with different Yamaha digital consoles. Don't think this would change anything for vMix.
Are you using a dedicated lan for Dante or the same network port you use for other purposes?
DreamAventure
#4 Posted : Sunday, January 21, 2024 1:51:35 AM(UTC)
DreamAventure
Allen & Heath DT168 or Yamaha TIO... Check software to control units before.
But may be worth to wait for new announcements of dante AV products.
Dedicate Dante network.
