Joined: 2/21/2023(UTC) Posts: 11  Location: Minnesota Thanks: 6 times
I'm attempting to save a vmix package to move to another workstation. Every time I do, I get the following error:
Part URI is not valid per rules defined in the Open Packaging Conventions specification.
and all it will do is save a preset without included elements. Any idea what I'm doing wrong?
Thanks!
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Use the save as drop down and select "save as bundle" it will include all resources to be moving to other devices.
Originally Posted by: mavik  Use the save as drop down and select "save as bundle" it will include all resources to be moving to other devices. Correct. That is what I did when I got the error. I'm trying to identify the error and save the bundle.
This error can be caused by special characters in the file names of assets used in your project.
For me it was a '#' in the file name of a video.
After renaming the file and relinking it, saving as a bundle works again.
