Renaming inputs does not work
Joined: 12/8/2022(UTC) Posts: 148  Thanks: 48 times Was thanked: 3 time(s) in 3 post(s)
Hi! I got a couple of inputs I want to rename. But when I press change after editing the input title vmix first says it needs to temporary stop the input. Then it shows the input select view. As if I am promped to create a new input. And when I do this I get the same input with the default name. Am I doing something wrong? Anyone having the same experience? The only documentation I have found is this help page and according to this it seems as if renaming inputs should be possible: https://www.vmix.com/hel...nputSettingsGeneral.htmlThanks in advance for any help with this! Im on version 26.0.0.45
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 317 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: TL68  Hi! I got a couple of inputs I want to rename. But when I press change after editing the input title vmix first says it needs to temporary stop the input. Then it shows the input select view. As if I am promped to create a new input. And when I do this I get the same input with the default name. Am I doing something wrong? Anyone having the same experience? The only documentation I have found is this help page and according to this it seems as if renaming inputs should be possible: https://www.vmix.com/hel...nputSettingsGeneral.htmlThanks in advance for any help with this! Im on version 26.0.0.45 choosing "change" is for CHANGING the SOURCE of the input Helpfile says: "Click Change to change the source of this input" Just type in the name you like to call the input in the NAME textbox and close that window . not extra confirmation needed unless ther is a OK/Cancel button at the bottom of the window
Originally Posted by: doggy  Originally Posted by: TL68  Hi! I got a couple of inputs I want to rename. But when I press change after editing the input title vmix first says it needs to temporary stop the input. Then it shows the input select view. As if I am promped to create a new input. And when I do this I get the same input with the default name. Am I doing something wrong? Anyone having the same experience? The only documentation I have found is this help page and according to this it seems as if renaming inputs should be possible: https://www.vmix.com/hel...nputSettingsGeneral.htmlThanks in advance for any help with this! Im on version 26.0.0.45 choosing "change" is for CHANGING the SOURCE of the input Helpfile says: "Click Change to change the source of this input" Just type in the name you like to call the input in the NAME textbox and close that window . not extra confirmation needed unless ther is a OK/Cancel button at the bottom of the window Aaah, it was that easy. Man I feel stupid now. It of course works great doing it the right way :-). Being an oldtimer I still have not completely grasped that changes can be made without clicking a Save-button :-) . Thanks for helping out, Doggy!
