Beta Discussion
XAML In/Out animations reversed - vMix 27.0.0.55
Hello, Thanks for all you do.
I noticed it was stated that in v27.0.0.50 thaat this was fix, I just updated to 0.0.55 & the problem still persist. Is there anything I need to do or can you check it?
Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4171 time(s) in 1498 post(s)
There must be something strange with a custom XAML file you are using, as the built in AnimatedInOutHD.xaml template is now working fine again.
Originally Posted by: admin There must be something strange with a custom XAML file you are using, as the built in AnimatedInOutHD.xaml template is now working fine again.
I am still experiencing this with a custom XAML file. It was not so before update. Any help?
Joined: 12/27/2012(UTC) Posts: 5,092 Location: Belgium Thanks: 284 times Was thanked: 921 time(s) in 760 post(s)
Originally Posted by: Soundfloss Originally Posted by: admin There must be something strange with a custom XAML file you are using, as the built in AnimatedInOutHD.xaml template is now working fine again.
I am still experiencing this with a custom XAML file. It was not so before update. Any help? Change the animations around in the code (IN <> OUT) vMix is mixing them up
Beta Discussion
