NSCPro
#1 Posted : Friday, December 8, 2023 6:59:26 AM(UTC)
NSCPro
Estonia
Hi.
How to make scrollable text. If text longer than graphics element, it's scrolling, other way, if text not long, no scrolling
Thank you
#2 Posted : Friday, December 8, 2023 12:16:56 PM(UTC)
Originally Posted by: NSCPro Go to Quoted Post
Hi.
Thank you
Code:
put text in textblock and ticker
calculate length of text
if length is longer than textblock
   show ticker
else
   show textblock
end if
NSCPro
#3 Posted : Friday, December 8, 2023 8:34:15 PM(UTC)
NSCPro
Estonia
I must add this code to script?
#4 Posted : Saturday, December 9, 2023 3:55:29 AM(UTC)
No this isnt the code. its a description of the logic to use
NSCPro
#5 Posted : Saturday, December 9, 2023 4:58:10 AM(UTC)
NSCPro
Estonia
Do you have some sample how do that?
Peter1000
#6 Posted : Saturday, December 9, 2023 6:21:04 AM(UTC)
Peter1000
Switzerland
Was thanked: 84 time(s) in 64 post(s)
Here is an example of how to determine the length of a text and perform different actions based on the length.
However, this is not a turnkey solution to your problem, that will require a little more work on your part.
There is probably also such an example in doggy's "scripting for dummies" always a worthwhile way to solve such questions.
Code:
dim text as string
dim count As Integer
'the next line gets a text from a title
text = input.find("Title 0- The Classic Blue.gtzip").Text("Headline.Text")
'the next line counts how many characters are in the text
count = text.length
console.writeline (text)
console.writeline (count)
If count > 10 Then
    console.writeline ("count is greater than 10")
    'here you could start your ticker
Else
    console.writeline ("count is not greater than 10")
    'here you could start your title
End If
'the console.writeline lines are only for your information in the script window
'adjust the number, in this example 10, to your needs
#7 Posted : Saturday, December 9, 2023 6:40:59 AM(UTC)
a textbox and a ticker having a width of about 15 characters for example of the used font (not precise when using proportional fonts ) one on top of the other
Code:
dim boxlength as integer = 15
do while true
dim TickerText as string = Input.Find("sometitle.gtzip").Text("TextBlock1.Text" )
dim length as integer= TickerText.Length()
If length >= boxlength
   API.Function("SetTextVisibleOff",Input:="textorticker.gtzip",SelectedName:="TextBlock1.Text" )
   API.Function("SetTextVisibleOn",Input:="textorticker.gtzip",SelectedName:="Ticker1.Text" )
else
   API.Function("SetTextVisibleOn",Input:="textorticker.gtzip",SelectedName:="TextBlock1.Text" )
   API.Function("SetTextVisibleOff",Input:="textorticker.gtzip",SelectedName:="Ticker1.Text" )
end if
sleep(100)
Loop
wonder why you don't use automatic textbox resizing instead as IMO it looks weird ( to put it nicely)
