TVIZME
#1 Posted : Wednesday, November 29, 2023 3:03:22 AM(UTC)
TVIZME
currently there is the capability of four monitor outs, i would like the option of more than one multi view to look at various sources
DT_Danny
#2 Posted : Monday, December 4, 2023 10:38:43 PM(UTC)
DT_Danny
Hi TVIZME,
Each input can already be set as a multiviewer using the layers. You can Also assign any source to any output already, thus creating an unlimited amount of custom multiviewer as any source (or multiviewer) can be assigned to any output.
Cheers,
TVIZME
#3 Posted : Tuesday, December 5, 2023 2:29:28 AM(UTC)
TVIZME
i am bot requesting the layers multiview, i am talking about the multiview output
Mike at SOTC
#4 Posted : Friday, December 8, 2023 3:33:51 AM(UTC)
Mike at SOTC
Interesting though, but there is no easy way to add the Program and Preview output to layers to be included in your custom multiview setup except through the provided multiviewer option.
#5 Posted : Friday, December 8, 2023 3:52:20 AM(UTC)
sure can as now there is an option to add preview and output both as an input so you can use them as layer content
Is worth it to read the helpfiles regarding inputs
Preview
The Preview input simply shows a copy of what is displayed in the Preview area of vMix.
This is useful for creating a custom MultiView Output when used in conjunction with the Output input.
Mike at SOTC
#6 Posted : Friday, December 8, 2023 4:39:47 AM(UTC)
Mike at SOTC
Ok I think we are talking about two things.
In the Layers / Multiview, I don't see a way to add Program or Preview.
Creating Multiviewer in Layers+Multiviewer.jpg (123kb) downloaded 0 time(s).
In the Outputs / NDI / SRT menu you can add program or preview but you cannot save more than 1 multiview setup. I have separate projects that need their own custom multiviewer setup. I need to be able to save the custom multiviewer here and in a different project I need to use different inputs for different monitors
Multiviewer in NDI setup.jpg (89kb) downloaded 0 time(s).
#7 Posted : Friday, December 8, 2023 5:15:40 AM(UTC)
you have to add them as inputs first; see helpfiles->inputs /same way a adding a mix input
then create your own multiview with the layer on a color input for example or customize
Screenshot 2023-12-07 202947.jpg (26kb) downloaded 0 time(s).
Aleksey.Nikt
#8 Posted : Tuesday, February 20, 2024 6:52:14 PM(UTC)
Aleksey.Nikt
Georgia
Preview
OK. But I can only add 10 layers to the input. We subtract 2 layers for pgm/preview and there are only 8 layers left for inputs in my “custom” multiview.
In this case, I will need to make several multiview inputs and overlay them on top of each other) And it will also be difficult to display the program/preview on the input thumbnail
Often, on my projects, I need a multiview that would display more than 10 inputs
Vmix needs to increase the number of multiview outputs to at least two and greater opportunities for their customization
Mike at SOTC
#9 Posted : Tuesday, February 20, 2024 11:36:52 PM(UTC)
Mike at SOTC
I completely agree. Having a multiple multiview setups would be very helpful!
IKONIK
#10 Posted : Wednesday, February 21, 2024 3:14:00 AM(UTC)
IKONIK
Hi, you can integrate an MLTW Input into another.
