kevev
#1 Posted : Thursday, December 7, 2023 1:42:01 PM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
Howdy! Would anyone be willing to share a script in vMix that will enable or disable trigger #2 in input #3?
I am stumped. Thank You in advance! :)
#2 Posted : Thursday, December 7, 2023 5:18:35 PM(UTC)
Code:
if triggerenable/disable shortcut is available
       use that
else
       use Trigger Manager
end if
richardgatarski on 12/7/2023(UTC)
kevev
#3 Posted : Friday, December 8, 2023 1:24:24 AM(UTC)
kevev
Code:
       use that
else
       use Trigger Manager
end if
lol now that is very funny!
How about a real script example? :)
nikosman88
#4 Posted : Friday, December 8, 2023 2:09:58 AM(UTC)
nikosman88
Greece
Code:
       use that
else
       use Trigger Manager
end if
Hello. Give real data what you need in order to receive real answer. Other than this.. No you cant do it directly. There is no way in vmix api to go in a automatic way in a specific input and check-uncheck the tick in a trigger. Only manually via the input or the trigger manager. I hope that in future vmix team will give us this feature
For now.. Any trigger is actually a shortcut that does something. So in order to do what you need is to write a script that in some conditions that exist or not,will run or not the shortcut-trigger
Unfortunatelly no shortcut to do the auto check-uncheck for a trigger
thanks 1 user thanked nikosman88 for this useful post.
kevev on 12/8/2023(UTC)
kevev
#5 Posted : Friday, December 8, 2023 2:33:36 AM(UTC)
kevev
Code:
       use that
else
       use Trigger Manager
end if
We have a show that has multiple segments. Segment 1, 2, 3, 4. Between the segments we have a bump out images with music, then automatically transition to a commercial video, then automatically transition to a bump in image with music. The bump in image has a trigger that on transition out after 2 seconds will enable overlay 2 which is the title of the next segment. We manually cut to a camera after the bump in image music overlay has completed. After Segment 4 we have the option of 2 different closing segments. I am not sure of the best way to handle this closing segment situation to allow for automation of the 2 second delayed overlay as this overlay could be one of 2 overlays depending on which closing segment we decide to use.
We cut to an image that has 3 triggers:
Trigger 1 is music
Trigger 2 is OnTransitionOut OverlayInput2In InputX Delay 2000
Trigger 3 is OnTransitionOut OverlayInput2In InputY Delay 2000
We would like to have 2 buttons:
Button A will Enable Trigger 2 & Disable Trigger 3
Button B will Disable Trigger 2 & Enable Trigger 3
This way when we cut to a camera the proper overlay will automatically.
#6 Posted : Friday, December 8, 2023 2:47:49 AM(UTC)
Trigger 1 is music
Use Dynamicx (x is number) for input in your trigger, use SetdynamicInputx to the desired inputnumber with a shortcut
