I have a host on stage and need to sent the audio to remote viewers, which is fine. But also need the remote viewers to talk.
Can I do some sort of mix minus to remove the hosts voice as the audio comes back from the viewers?
Sort of what vcall does but I can't use that?
Originally Posted by: jameshallspanner  I have a host on stage and need to sent the audio to remote viewers, which is fine. But also need the remote viewers to talk.
Sort of what vcall does but I can't use that? Hello. In a studio with a big echo in which i send through speakers the audio from skype and the mic from the person in the studio catch this audio and bring in echo i used the vst3 audio plugin https://www.wtautomixer.com/ i insert it to every audio in source and it did the magic thing. Maybe it can work in your workflow
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Originally Posted by: dmwkr  Right. I forgot to write that i send only the mic audio through an Audio Bus and from another one audio bus assigned to an audio device only the viewers audio in the studio but this not prevent the echo 100% if the audio from the viewers has to be loud in the studio and in my situation the plugin helped a lot
