NDI
NDI no longer works
Good morning, I need some information. I work with three IP cameras: No. 1 Aida Imaging HD-NDI-200 No. 2 Zowietek PTZ Streaming Camera with NDI.
Until a couple of weeks ago, you were quietly importing NDI cameras with Vmix 4K ver. 25.0.0.34x64. Now it no longer sees the cameras. has anything changed? Is it necessary to purchase a license? Thanks for the help
Please try with the latest version. There are constant fixes and progressive improvements on NDI side as well as vMix side.
Thank you for your response. I installed NDI version 5.6.0. My senzaition is that it doesn't work anymore since I installed the new version NDI tools.
I think Mavic meant that you might need a more recent version of vMix, of which the current version is 26.0.0.45, whereas you're still on v25.0.0.34. Plus, vMix v27 is not far away - currently in a public Beta phase - so there have been a lot of updates (some major, some minor) since the version you're using.
Correct yes. All three (Windows, NDI, vMix) should be updated to the latest. You can check the NDI signal with the Studio Monitor app. If that shows the signal you know it's vMix itself. If the studio monitor doesn't show the NDI you have a problem somewhere else. Most likely the network or Windows.
Thank you!!! - NDI is the latest version - Windows 10 updated - I just have to buy the Vmix 26 version As I wrote, the curious thing is that it stopped working by updating NDI tools. It always worked for me before.  Cattura.PNG (138kb) downloaded 2 time(s).
NDI
NDI no longer works
