Joined: 7/8/2023(UTC) Posts: 21  Location: Great State of Tennessee Thanks: 12 times
Is there a way to change the playlist names and where would I find the master file on my system so I can create a backup copy of the playlists file. Thanks
Originally Posted by: talkinlive  Is there a way to change the playlist names and where would I find the master file on my system so I can create a backup copy of the playlists file. Thanks One can create a new playlist and select copy current playlist ( followed by deleting old one if needed) The content of the playlists (and its settings) are saved in the preset files
