GT
Ticker speed and loop
Joined: 10/24/2023(UTC) Posts: 3  Location: caifornia Thanks: 5 times
Hi all,
Does anyone know how to change the speed of a ticker? At default it is at a very slow pace and I would like it to be a little faster.
Secondly, is there a way to loop the text? Meaning if my last word is "...yellow." and first word is "There...", it will look like "...yellow. There..." instead of "yellow._________(space here)__________There...". Just want to cut that space out. Hopefully that made sense. Thanks
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
To change the speed, right click the input. Select title editor. Then in the title bar, click the clock icon. You can change the speed there.
As for the other issue, I don't think there is a way. You will probably need to put in a feature request.
 1 user thanked kross for this useful post.
Originally Posted by: jas105  Hi all,
Secondly, is there a way to loop the text? Meaning if my last word is "...yellow." and first word is "There...", it will look like "...yellow. There..." instead of "yellow._________(space here)__________There...". Just want to cut that space out. Hopefully that made sense. Thanks create a csv file with the same text in 2 rows , add a space to one of the rows of text (so both rows are different in content) Set datasource to "Auto Next"and "loop" link the ticker to the datasource and set its type to "add" play wiht the speed setting of the ticker and the autonext speed of the datasource to get the spacing to your liking
GT
