hi all, The Clip name in the vMix too small.See attachment.  11111.jpg (11kb) downloaded 2 time(s).How to adjust the font size? Sometime i have more than 30 clips ,it so hard to find the clip i need.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: apolloyangyu  hi all, The Clip name in the vMix too small. How to adjust the font size? Sometime i have more than 30 clips ,it so hard to find the clip i need. Even if the font would be bigger one still would have to scroll through the many inputs A good idia is to use the available categories and spread those inputs amongst them
thanks doggy even if i have only 10 clip ,the fonts size is too small. i hope i can adjust the font siez or how to try another font type?
Joined: 7/1/2023(UTC) Posts: 16  Location: Bridgetown Thanks: 2 times
I agree that the font size is small, but that is not a bother to me, as I use PanelBuilder, and I have the ability to use larger font sizes, or use a second monitor with multiview output....only shortcoming is that you will only see 8 inputs at any time.....When I have many clips, I use PanelBuilder and bring in my clips as a list, so I can shuffle through them, or set them in the order I want them to play. You can use a list, and you will have a better view of the clips in vmix
