cody@raceontexas.com
#1 Posted : Friday, October 20, 2023 12:12:17 AM(UTC)
When using an overlay now it is sticking on and not turning off and resetting. You have to go into the input and manually click the layer number to make it turn off and reset before you can you it again.
#2 Posted : Friday, October 20, 2023 12:36:22 AM(UTC)
Was thanked: 4171 time(s) in 1498 post(s)
I'm not able to replicate this, can you please provide step by step, as it sounds like maybe there is an issue with a specific title template being used or something along those lines?
#3 Posted : Friday, October 20, 2023 12:55:51 AM(UTC)
Here is what is happening.
I am using a custom made mov file. I have also done it with a mp4 file that was music and when it was done playing it did not clear the overlay either. It just leaves the overlay layer on until you click it again to turn it off and reset it.
dmwkr
#4 Posted : Friday, October 20, 2023 1:36:57 AM(UTC)
dmwkr
Was thanked: 119 time(s) in 108 post(s)
That's normal behavior for all the vMix versions I know. :) You have to set a trigger "OnCompletion" (or with a delay "OnOverlayIn") to turn it off.
#5 Posted : Friday, October 20, 2023 1:45:36 AM(UTC)
I did not know that. Thanks. I will setup some triggers. Would be nice if in the future though it would auto turn off the overlays ones the time is up.
#6 Posted : Friday, October 20, 2023 1:58:28 AM(UTC)
Its turning off the overlay, but its butting off the music playing even with a delay. The video is 8 seconds, and the audio is 50. I set the delay to 50,000 and its cutting the overlay and audio off with 12 seconds left. Even tried going to 100,000 and it still cuts it off at 12 seconds left. Any ideas on this?
#7 Posted : Friday, October 20, 2023 2:10:29 AM(UTC)
I made it work with 2 triggers.
