fgolman
#1 Posted : Tuesday, October 17, 2023 1:45:01 PM(UTC)
fgolman
I had seen the document that defined all the types of inputs, outputs, references etc (EG, input:="xxx") but now I can't seem to find it again.
Any pointers to it would be appreciated.
Thank you,
Fritz Golman
iHeartMedia
Roy Sinclair
#2 Posted : Thursday, October 19, 2023 6:31:16 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
fgolman
#3 Posted : Thursday, October 19, 2023 6:38:25 AM(UTC)
fgolman
I'm quite familiar with the API reference but what I was specifically looking for is where the definition of all the different types of how to encode the various values in scripting.
Roy Sinclair
#4 Posted : Thursday, October 19, 2023 7:27:48 AM(UTC)
Roy Sinclair
This? https://www.vmix.com/hel...utFunctionReference.html
fgolman
#5 Posted : Thursday, October 19, 2023 7:44:31 AM(UTC)
fgolman
Once again, not sure why you're sending me to the API function reference, but this is not what I'm looking for.
Peter1000
#6 Posted : Thursday, October 19, 2023 3:09:01 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
this is exactly what you are looking for
https://vmixapi.com/
WaltG12
#7 Posted : Monday, October 23, 2023 6:49:40 AM(UTC)
WaltG12
It's unclear what you're asking.
Are you looking for a resource to help write a script to do something or to retrieve something?
If you're looking for the former, that'd be the link Roy provided (twice) which is duplicated in the link Peter provided. Both seem to provide the exact same information, which is the information.
If you want the latter, however, I'm not sure such a list of variables/syntax exists. At least, none that's vMix specific. You can probably parse the XML to get variable names, but the syntax required to properly use them is, as far as I can tell, tied to general knowledge of VB.net scripting. As I mentioned, I'm not familiar with any resource that provides that in a vMix specific manner.
Roy Sinclair
#8 Posted : Tuesday, October 24, 2023 7:55:25 AM(UTC)
Roy Sinclair
Are you looking for this: http://127.0.0.1:8088/api
That's the URL which brings back the (incomplete) status of the currently running vMix configuration.
I call it incomplete because it gives us what the people at vMix think we want to know but doesn't always contain the exact bit of information we really need to know. That's why there are numerous requests for additions to it in the Feature Requests.
