formatta2003
#1 Posted : Tuesday, October 17, 2023 11:20:16 PM(UTC)
formatta2003
Hello and thanks. I have a tip for PTZ!
if I create 2/3/4/etc ptz presets the various virtual channels are created with the preview.
Perfect! but when I put one of these channels on air, ALL the relevant virtual inputs and the master ptz of this channel should be reported as on air!!!!
not only the ptz actually on air... practically if cam1 is on air all the other ptz presets cannot be touched to avoid sudden movements on air.....
there are 2 pieces of advice, the first is to put the color red to all the relevant channels and secondly I recommend putting among the PTZ channel options the ability to block movements when the relevant camera is onair..
basically, when cam1 is on the air, by pressing the preview of the various PTZs, nothing happens....furthermore, all the PTZs of the relevant channel are red/danger
thanks sorry if my english is not perfect, I'm using google translator. I hope you understand what I mean
PeterH
#2 Posted : Wednesday, October 18, 2023 6:22:37 AM(UTC)
PeterH
+1
